I have just installed File Reporter 2.6.1 onto a Windows 2012R2 Server with Postgres running locally on the Windows server.
The server is NOT part of an Active Directory (i.e it is in a workgroup.)
I seem to have some kind of Windows account error but not sure what. Please see my log file.
Any help would be greatly appreciated.
Thanks
Peter
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Engine completed getting O.S. version information, OS = "O.S. Name: Microsoft Windows, Architecture: x86_64, Platform ID: 2, Version: v6.3, Build: 0, SP: v0.0 [], Product Type: 3, Suite Mask: 0x80000110", Result = 0.
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Engine is getting file version information for itself ["C:\Program Files\Novell\File Reporter\Engine\NFREngine.exe"]...
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Engine completed getting file version information for itself, Version = "2.6.1.2", Result = 0.
01 2015-09-13 22:36:17 36000 5 8003 1964 3220 GetServerDSCapabilityFlags() - The Primary Domain SID for the local system is empty. This system is not part of an AD domain.
01 2015-09-13 22:36:17 36000 5 8003 1964 3220 GetServerDSCapabilityFlags() - The Novell XPLAT API Libraries are loaded.
01 2015-09-13 22:36:17 36000 5 8003 1964 3220 GetServerDSCapabilityFlags() - The Novell XPLAT API Libraries are initialized.
01 2015-09-13 22:36:17 36000 5 8003 1964 3220 GetServerDSCapabilityFlags() - The Novell XPLAT API Libraries are using the Windows version of XTIER.
01 2015-09-13 22:36:17 36000 5 8003 1964 3220 GetServerDSCapabilityFlags() - This system has Novell eDir XPLAT capability.
82 2015-09-13 22:36:17 36000 0 ff08 1964 2308 <CONFIG><LEVEL>5</LEVEL><CATEGORY/></CONFIG>
82 2015-09-13 22:36:17 36000 0 ff09 1964 2308 <CONFIG><LEVEL>5</LEVEL><CATEGORY/></CONFIG>
82 2015-09-13 22:36:17 36000 0 ff0f 1964 2308 <CONFIG><LEVEL>5</LEVEL><CATEGORY/></CONFIG>
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Loading saved state information...
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Completed loading state information, bOK = 1.
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Validating the credentials set...
01 2015-09-13 22:36:17 36000 3 0001 1964 3220 ML: Credentials "***Windows***" are not valid due to a missing account name, salt value or rights group.
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Completed validating the credentials set, bOK = 1.
01 2015-09-13 22:36:17 36000 2 0001 1964 3220 ML: Called xDSContext.UseDefaultSecurityCtx(...), Result = 183.
01 2015-09-13 22:36:17 36000 1 0001 1964 3220 ML: Failed to initialize 1 or more components and/or subsystems. Engine is switching to stop-pending state.
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Engine is shutting down...
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Stopping the Security Context Pool Service...
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Saving state information...
01 2015-09-13 22:36:17 36000 5 0001 1964 3220 ML: Completed saving state information, bOK = 1.
01 2015-09-13 22:36:17 36000 2 0001 1964 3220 ML: Engine has shut down. Thread is terminating...
01 2015-09-13 22:36:17 36000 0 8001 1964 2308 Shutting down the Logger. Closing log file "C:\ProgramData\Novell\File Reporter\Engine\log\nfrengine-20150913-183349.log".
81 2015-09-13 22:36:17 36000 0 8001 1964 2308 <LOGFILECLOSE/>
