problem to create scan targets
dear,
I installed the Novell File Reporter 2.0.1, but I have a problem. Upon configuration scan targets by clicking add storage resource browser window appears only the domain name, without any check box to select the directories to perform the procedure.
What can it be? My servirdor is a windows 2008 with re activity directory.
graciously
    On 6/12/2013 2:36 PM, marcleim wrote:
    > dear,
    > directory.
    > graciously
    marcleim,
    Do you get a more complete list of your storage resources in
    Administration > Storage Resources? Including volumes for each server?
    If not, we may not have enough rights to enumerate volumes on these
    servers; make sure that the NFRProxyRights group has Supervisor rights
    at the root of your tree.
    - NFMS Support Team
    dear, forgive me for the delay in responding, but I was busy with other things.
    Well, I'm generating reports, but the report by Permissions identity is not bringing data information. I insert the identities, but the page that should provide me the data is blank.
    what can be?
    dear,
    Thanks for the help, the problems were resolved the NFR is working perfectly.
    God bless you.
