failed to connect postgresql while installation igm
hi all
need some advice, i had assessment to this product, i follow the installation for igm.
prepared the prerequisites also, like  Zulu OpenJDK and Apache Tomcat application server.
but when step test connect of postgres it was failed, any suggest what should i check?
because try to login to postgres had no issue with user and pass, also see jdbc installed
Parents
    When you do the install, it asks you for the path to the SQL JDBC connector specific to the DB you are using.  Did you successfully pass that along?  I see a screen shot of its path included.  BUt want to confirm.
    Does your password have any comic book cursewords in it?  You know the specials?  Sometimes the installer has issues escaping odd characters. (It is a GUI, calling to a script, which calls a util, and all it takes is one bad escaping there to break).
    Try a simpler password for the install.  (Make it complex, just skip ! %& ? style values for now).
    this when select the db right?
  • 0   in reply to
    Hello,
    1) The question about connecting to the Database was during the Identity Governance installation. There is page where one can test the connection to the database server. Did that work?
    2) Did you update the configuration of Postgres Server to allow for JDBC connections from other hosts besides "localhost"?
    Sincerely,
    Steven Williams
    Principal Enterprise Architect
    OpenText Cybersecurity
  • 0   in reply to
    Hello,
    3) Did you utilize our Installation Sample Helper scripts from the Documentation site to configure this Windows environment.
    Sincerely,
    Steven Williams
    i try use this one but somehow cannot found the file,
    Windows PowerShell transcript start
    Start time: 20240909223215
    Username: IGM\admin
    RunAs User: IGM\admin
    Configuration Name:
    Machine: IGM (Microsoft Windows NT 10.0.20348.0)
    Host Application: C:\Windows\system32\WindowsPowerShell\v1.0\PowerShell_ISE.exe
    Process ID: 696
    PSVersion: 5.1.20348.1366
    PSEdition: Desktop
    PSCompatibleVersions: 1.0, 2.0, 3.0, 4.0, 5.0, 5.1.20348.1366
    BuildVersion: 10.0.20348.1366
    CLRVersion: 4.0.30319.42000
    WSManStackVersion: 3.0
    PSRemotingProtocolVersion: 2.3
    SerializationVersion: 1.1.0.1
    Transcript started, output file is C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\logs\IDGov-Core-Helper.log
     Extracting "C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\compressed\zulu11.74.15-ca-jdk11.0.24-win_x64.zip" into "c:\netiq\idm\apps\jdk":
    Exception calling "ExtractToDirectory" with "2" argument(s): "Could not find file
    'C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\compressed\zulu11.74.15-ca-jdk11.0.24-win_x64.zip'."
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:150 char:5
    +     [System.IO.Compression.ZipFile]::ExtractToDirectory(${zip}, ${des ...
        + CategoryInfo          : NotSpecified: (:) [], MethodInvocationException
        + FullyQualifiedErrorId : FileNotFoundException
     Creating symbolic link at c:\netiq\idm\apps\jre for jdk\jre
     Extracting "C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\compressed\apache-activemq-5.17.6-bin.zip" into "c:\netiq\idm\apps\activemq":
     Extracting "C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\compressed\apache-tomcat-9.0.93-windows-x64.zip" into "c:\netiq\idm\apps\tomcat":
    'C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\compressed\apache-tomcat-9.0.93-windows-x64.zip'."
     Moving the default Tomcat wars to c:\netiq\idm\apps\backup:
    New-Item : An item with the specified name C:\netiq\idm\apps\backup already exists.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:266 char:14
    + ...    $null = (New-Item -Path "${DIR_BASE}" -Name "${DIR_BACKUP}" -ItemT ...
        + CategoryInfo          : ResourceExists: (C:\netiq\idm\apps\backup:String) [New-Item], IOException
        + FullyQualifiedErrorId : DirectoryExist,Microsoft.PowerShell.Commands.NewItemCommand
     Creating new default Tomcat index file at c:\netiq\idm\apps\tomcat\webapps\ROOT\index.html:
     Disabling Tomcat AJP connector within "c:\netiq\idm\apps\tomcat\conf\server.xml"
    Get-Content : Cannot find path 'C:\netiq\idm\apps\tomcat\conf\server.xml' because it does not exist.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:185 char:16
    + ...  -Value "$((Get-Content `"${DIR_BASE}\${DIR_TOMCAT}\conf\server.xml`" ...
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\apps\tomcat\conf\server.xml:String) [Get-Content],
    ItemNotFoundException
        + FullyQualifiedErrorId : PathNotFound,Microsoft.PowerShell.Commands.GetContentCommand
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\apps\tomcat\conf\server.xml:String) [Get-Content], ItemNotFoundException
    Set-Content : Could not find a part of the path 'C:\netiq\idm\apps\tomcat\conf\server.xml'.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:183 char:3
    +   Set-Content `
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\apps\tomcat\conf\server.xml:String) [Set-Content],
    DirectoryNotFoundException
        + FullyQualifiedErrorId : GetContentWriterDirectoryNotFoundError,Microsoft.PowerShell.Commands.SetContentCommand
    +   Set-Content `
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\apps\tomcat\conf\server.xml:String) [Set-Content], DirectoryNotFoundException
     Enable Output to CATALINA_OUT:
    Get-Content : Cannot find path 'C:\netiq\idm\apps\tomcat\bin\catalina.bat' because it does not exist.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:206 char:14
    + ...    $text = (Get-Content -Path "${DIR_BASE}\${DIR_TOMCAT}\bin\catalina ...
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...in\catalina.bat:String) [Get-Content],
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...in\catalina.bat:String) [Get-Content], ItemNotFoundException
    Set-Content : Could not find a part of the path 'C:\netiq\idm\apps\tomcat\bin\catalina.bat'.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:207 char:103
    + ... RUNJAVA%' | Set-Content -Path "${DIR_BASE}\${DIR_TOMCAT}\bin\catalina ...
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...in\catalina.bat:String) [Set-Content],
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...in\catalina.bat:String) [Set-Content], DirectoryNotFoundException
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:208 char:14
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:209 char:69
    + ... UT% 2>&1' | Set-Content -Path "${DIR_BASE}\${DIR_TOMCAT}\bin\catalina ...
     Copying the ActiveMQ and log4j-api jar to c:\netiq\idm\apps\tomcat\lib:
     Prepare c:\netiq\idm\apps\tomcat\bin\start-tomcat.bat:
    PS>TerminatingError(Copy-Item): "Could not find a part of the path 'C:\netiq\idm\apps\tomcat\bin\start-tomcat.bat'."
    Copy-Item : Could not find a part of the path 'C:\netiq\idm\apps\tomcat\bin\start-tomcat.bat'.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:293 char:5
    +     Copy-Item -Path "${DIR_PRISTINE}\${NAME_TOMCAT_LAUNCH}" -Destinat ...
        + CategoryInfo          : NotSpecified: (:) [Copy-Item], DirectoryNotFoundException
        + FullyQualifiedErrorId : System.IO.DirectoryNotFoundException,Microsoft.PowerShell.Commands.CopyItemCommand
    Get-Content : Cannot find path 'C:\netiq\idm\apps\tomcat\bin\start-tomcat.bat' because it does not exist.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:294 char:14
    + ...    $text = (Get-Content -Path "${DIR_BASE}\${DIR_TOMCAT}\bin\${NAME_T ...
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...tart-tomcat.bat:String) [Get-Content],
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...tart-tomcat.bat:String) [Get-Content], ItemNotFoundException
    Set-Content : Could not find a part of the path 'C:\netiq\idm\apps\tomcat\bin\start-tomcat.bat'.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:295 char:60
    + ... IR_BASE}" | Set-Content -Path "${DIR_BASE}\${DIR_TOMCAT}\bin\${NAME_T ...
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...tart-tomcat.bat:String) [Set-Content],
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...tart-tomcat.bat:String) [Set-Content], DirectoryNotFoundException
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:296 char:14
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:297 char:71
    + ... DIR_JDK}" | Set-Content -Path "${DIR_BASE}\${DIR_TOMCAT}\bin\${NAME_T ...
     Prepare c:\netiq\idm\apps\tomcat\bin\stop-tomcat.bat:
    PS>TerminatingError(Copy-Item): "Could not find a part of the path 'C:\netiq\idm\apps\tomcat\bin\stop-tomcat.bat'."
    Copy-Item : Could not find a part of the path 'C:\netiq\idm\apps\tomcat\bin\stop-tomcat.bat'.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:303 char:5
    +     Copy-Item -Path "${DIR_PRISTINE}\${NAME_TOMCAT_QUIT}" -Destinatio ...
    Get-Content : Cannot find path 'C:\netiq\idm\apps\tomcat\bin\stop-tomcat.bat' because it does not exist.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:304 char:14
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...stop-tomcat.bat:String) [Get-Content],
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...stop-tomcat.bat:String) [Get-Content], ItemNotFoundException
    Set-Content : Could not find a part of the path 'C:\netiq\idm\apps\tomcat\bin\stop-tomcat.bat'.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:305 char:60
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...stop-tomcat.bat:String) [Set-Content],
        + CategoryInfo          : ObjectNotFound: (C:\netiq\idm\ap...stop-tomcat.bat:String) [Set-Content], DirectoryNotFoundException
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:306 char:14
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:307 char:71
     Create the Tomcat service IDM Apps Tomcat Service:
    PS>TerminatingError(Copy-Item): "Could not find a part of the path 'C:\netiq\idm\apps\tomcat\bin\TomcatService.exe'."
    Copy-Item : Could not find a part of the path 'C:\netiq\idm\apps\tomcat\bin\TomcatService.exe'.
    At C:\Users\admin\Documents\install-helper-scripts-4.2.0-win\windows\install.ps1:313 char:5
    +     Copy-Item -Path "${DIR_PRISTINE}\${NAME_TOMCAT_SERVICE}" -Destina ...
    Status   Name               DisplayName
    Stopped  IDM Apps Tomcat... IDM Apps Tomcat Service
     Installing PostgreSQL to c:\netiq\idm\apps\postgres:
     Updating PostgreSQL to allow remote access
     Restarting PostgreSQL
     Complete the transcript
    Windows PowerShell transcript end
    End time: 20240909223632
  • 0   in reply to
    Hello,
       If you already installed Tomcat, JDK, ActiveMQ, and Postgres on this Windows server, you can not utilize the "Install" helper scripts.  That script can only be utilized on a new Windows machine set-up.
    Sincerely,
    Steven Williams
Reply Children
No Data
