WebInspect standalone and ScanCentral DAST controller on docker
hello
Does somebody configured WebInspect standalone wo work with SC DASTcontainer? Where I can get any tutorial? I haven't found strict information on WI or DAST guide.
I've copied WI docker config to standalone API and its is active.
I'm not sure how to configure sersor service. When I typed
https://sc-dast-controller-IP-address/api
in "Manager URL", and SSC account as "Sensor Authentication" I received error: "The AMP Manager was not found. ..."
WI and DAST are in current version.
Any suggestions?
Thank you in advance
Pawel
Parents Reply
  • in reply to
    Thank you HansEnders for your links too.
    Here is many valuable knowledge to acuire :).
    At this moment service has started and registered in SSC console.
    Thank you for your quick and detailed reply.
    Have a nice day
    Pawel
Children
  • in reply to
    Hi Guys,
    I have same issue when start service got error 1053, already install dotNet SDK 5.0.408 (x64) still unable to start
    I have concern on appsetting.json on line 9 DASTroot URL need fill IP of WI API or DAST API running on Container which already add to SSC?
    Because previusly i used DAST API container and also sensor container, got error ssctoken not authenticated. so i try to use WI as a Sensor Service. But got issue error 1053
    anyone can give advice
    Thanks
    Rizal S
