I want to use Fortify extension of vs code for my angular 15 project, I have SCA 23.2.0.
I am using Windows 11 and Visual studio code 1.92.1. Can you explain detailed information through Video that would help me to understand better.
Thanks
  • Suggested Answer
    Have you researched our Fortify Unplugged channel on YouTube?  Did these videos on Fortify and the VS Code IDE help you understand how to scan within Visual Studio?
    Additional resource in Marketplace:  https://marketplace.visualstudio.com/items?itemName=fortifyvsts.fortify-extension-for-vs-code
    Typically, you would download the Fortify SCA Tools installer, run that, and select the desired IDE plugin(s) to add to your workstation.  You must have the selected IDE(s) installed prior to running this installer. If you need to update the IDE later, or you forgot and you installed the IDE after you installed the plugin to other IDEs on your workstation, then simply re-run this installer and make that same IDE selection again, and that will add the Fortify SCA plugin to that IDE.
    Be aware as you hunt on-line for video guides on this installation, that Fortify produces and supports a number of IDE plugins/extensions.
    • Static Code Analyzer - Visual Studio
    • Static Code Analyzer - Eclipse
    • Static Code Analyzer - IntelliJ
    • Static Code Analyzer - VS Code
    • Static Code Analyzer for FOD users (Remediation only) - Visual Studio
    • Static Code Analyzer for FOD users (Remediation only) - Eclipse
    • Static Code Analyzer for FOD users (Remediation only) - IntelliJ
    • Static Code Analyzer for FOD users (Remediation only) - VS Code
    • Security Assistant (Shift Left "security spell checker) - Visual Studio
    • Security Assistant (Shift Left "security spell checker) - Eclipse
    • Security Assistant (Shift Left "security spell checker) - IntelliJ
