Hello everyone.
Our clean deployment of SSC, more specifically the webapp component, cannot start.
I've also tried to delete the DB, increase the node size, increase the memory request, but without success.
Logs from the pod:
NOTE: Picked up JDK_JAVA_OPTIONS: --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED 30-Jul-2024 11:26:16.843 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/9.0.88 30-Jul-2024 11:26:16.855 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Apr 9 2024 13:22:30 UTC 30-Jul-2024 11:26:16.856 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 9.0.88.0 30-Jul-2024 11:26:16.856 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Linux 30-Jul-2024 11:26:16.857 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1.94 30-Jul-2024 11:26:16.859 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64 30-Jul-2024 11:26:16.861 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /usr/lib/jvm/java-17-openjdk-17.0.11.0.9-2.el9.x86_64 30-Jul-2024 11:26:16.861 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 17.0.11+9-LTS 30-Jul-2024 11:26:16.861 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Red Hat, Inc. 30-Jul-2024 11:26:16.862 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /app/tomcat 30-Jul-2024 11:26:16.862 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /app/tomcat 30-Jul-2024 11:26:16.926 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED 30-Jul-2024 11:26:16.927 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED 30-Jul-2024 11:26:16.927 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED 30-Jul-2024 11:26:16.927 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util.concurrent=ALL-UNNAMED 30-Jul-2024 11:26:16.927 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED 30-Jul-2024 11:26:16.928 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/app/tomcat/conf/logging.properties 30-Jul-2024 11:26:16.928 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager 30-Jul-2024 11:26:16.928 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048 30-Jul-2024 11:26:16.928 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources 30-Jul-2024 11:26:16.928 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0007 30-Jul-2024 11:26:16.929 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:MaxRAMPercentage=50.0 30-Jul-2024 11:26:16.929 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true 30-Jul-2024 11:26:16.929 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseContainerSupport 30-Jul-2024 11:26:16.929 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:MaxRAMPercentage=86.0 30-Jul-2024 11:26:16.929 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcom.fortify.ssc.logPath=/fortify/ssc/logs 30-Jul-2024 11:26:16.930 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs= 30-Jul-2024 11:26:16.930 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/app/tomcat 30-Jul-2024 11:26:16.930 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/app/tomcat 30-Jul-2024 11:26:16.930 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/fortify/tomcat/temp 30-Jul-2024 11:26:18.050 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio2-8080"] 30-Jul-2024 11:26:18.217 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["https-jsse-nio2-8443"] 30-Jul-2024 11:26:19.738 INFO [main] org.apache.tomcat.util.net.AbstractEndpoint.logCertificate Connector [https-jsse-nio2-8443], TLS virtual host [_default_], certificate type [UNDEFINED] configured from keystore [/app/secrets/keystore.jks] using alias [tomcat] with trust store [null] 30-Jul-2024 11:26:19.740 INFO [main] org.apache.catalina.startup.Catalina.load Server initialization in [3643] milliseconds 30-Jul-2024 11:26:19.754 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina] 30-Jul-2024 11:26:19.754 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/9.0.88] 30-Jul-2024 11:26:42.390 WARNING [main] org.apache.catalina.webresources.AbstractFileResourceSet.logIgnoredSymlink Resource for web application [] at path [/log] was not loaded as the canonical path [idge] did not match. Use of symlinks is one possible cause. 30-Jul-2024 11:26:42.943 INFO [main] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time. 2024-07-30 11:26:45,127 [INFO] com.fortify.ssc.webapp.SscSpringBootApplication - Deploying application 2024-07-30 11:26:45,979 [INFO] com.fortify.ssc.config.AutoConfig - Using autoconfig appProperties from environment: host.url, searchIndex.location, com.fortify.ssc.enforceSecureTransport 2024-07-30 11:26:46,029 [INFO] com.fortify.ssc.config.AutoConfig - Using autoconfig extra seeds: 200-Fortify_Process_Seed_Bundle-2024_Q2_0005.zip, 300-Fortify_PCI_Basic_Seed_Bundle-2024_Q2_0005.zip, 300-Fortify_PCI_SSF_Basic_Seed_Bundle-2024_Q2_0005.zip, 300-Fortify_Report_Seed_Bundle-2024_Q2_0005.zip 2024-07-30 11:26:46,353 [INFO] com.fortify.ssc.webapp.SscApplicationConfigurer - SSC is not configured, autoconfiguration will be started 2024-07-30 11:26:48,027 [INFO] com.fortify.ssc.webapp.SscApplicationConfigurer - Starting service auto-configuration 2024-07-30 11:26:48,348 [INFO] com.fortify.ssc.init.AutoConfigService - Starting database migration 2024-07-30 11:27:18,803 [ERROR] com.fortify.ssc.webapp.SscApplicationConfigurer - Auto-configuration failed, forcing maintenance mode com.fortify.ssc.init.exception.AppInitException: Error migrating database Cannot create PoolableConnectionFactory (Socket fail to connect to host:address=(host=secpipe-fortimysql-dev.c9rybzy08cmm.eu-west-1.rds.amazonaws.com)(port=3306)(type=primary). Connect timed out) at com.fortify.ssc.init.process.MigrationRunner.runMigration(MigrationRunner.java:63) ~[ssc-init-24.2.0.0186.jar:?] at com.fortify.ssc.init.AutoConfigService.automate(AutoConfigService.java:50) ~[ssc-init-24.2.0.0186.jar:?] at com.fortify.ssc.webapp.SscApplicationConfigurer.autoconfigure(SscApplicationConfigurer.java:142) ~[classes/:?] at com.fortify.ssc.webapp.SscApplicationConfigurer.lambda$buildContextInitializer$1(SscApplicationConfigurer.java:127) ~[classes/:?] at org.springframework.boot.SpringApplication.applyInitializers(SpringApplication.java:605) [spring-boot-2.7.18.jar:2.7.18] at org.springframework.boot.SpringApplication.prepareContext(SpringApplication.java:374) [spring-boot-2.7.18.jar:2.7.18] at org.springframework.boot.SpringApplication.run(SpringApplication.java:307) [spring-boot-2.7.18.jar:2.7.18] at org.springframework.boot.web.servlet.support.SpringBootServletInitializer.run(SpringBootServletInitializer.java:175) [spring-boot-2.7.18.jar:2.7.18] at org.springframework.boot.web.servlet.support.SpringBootServletInitializer.createRootApplicationContext(SpringBootServletInitializer.java:155) [spring-boot-2.7.18.jar:2.7.18] at org.springframework.boot.web.servlet.support.SpringBootServletInitializer.onStartup(SpringBootServletInitializer.java:97) [spring-boot-2.7.18.jar:2.7.18] at com.fortify.ssc.webapp.SscSpringBootApplication.onStartup(SscSpringBootApplication.java:62) [classes/:?] at org.springframework.web.SpringServletContainerInitializer.onStartup(SpringServletContainerInitializer.java:174) [spring-web-5.3.31.jar:5.3.31] at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4901) [catalina.jar:9.0.88] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) [catalina.jar:9.0.88] at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1345) [catalina.jar:9.0.88] at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1335) [catalina.jar:9.0.88] at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?] at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) [tomcat-util.jar:9.0.88] at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) [?:?] at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:876) [catalina.jar:9.0.88] at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:794) [catalina.jar:9.0.88] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) [catalina.jar:9.0.88] at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1345) [catalina.jar:9.0.88] at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1335) [catalina.jar:9.0.88] at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?] at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) [tomcat-util.jar:9.0.88] at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) [?:?] at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:876) [catalina.jar:9.0.88] at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:248) [catalina.jar:9.0.88] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) [catalina.jar:9.0.88] at org.apache.catalina.core.StandardService.startInternal(StandardService.java:470) [catalina.jar:9.0.88] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) [catalina.jar:9.0.88] at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:951) [catalina.jar:9.0.88] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) [catalina.jar:9.0.88] at org.apache.catalina.startup.Catalina.start(Catalina.java:735) [catalina.jar:9.0.88] at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?] at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?] at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?] at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?] at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345) [bootstrap.jar:9.0.88] at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:473) [bootstrap.jar:9.0.88] Caused by: java.sql.SQLException: Cannot create PoolableConnectionFactory (Socket fail to connect to host:address=(host=secpipe-fortimysql-dev.c9rybzy08cmm.eu-west-1.rds.amazonaws.com)(port=3306)(type=primary). Connect timed out) at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:653) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:531) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:731) ~[commons-dbcp2-2.9.0.jar:2.9.0] at com.fortify.ssc.init.process.MigrationRunner.runMigration(MigrationRunner.java:54) ~[ssc-init-24.2.0.0186.jar:?] ... 40 more Caused by: java.sql.SQLNonTransientConnectionException: Socket fail to connect to host:address=(host=secpipe-fortimysql-dev.c9rybzy08cmm.eu-west-1.rds.amazonaws.com)(port=3306)(type=primary). Connect timed out at org.mariadb.jdbc.client.impl.ConnectionHelper.connectSocket(ConnectionHelper.java:137) ~[mariadb-java-client-3.1.4.jar:?] at org.mariadb.jdbc.client.impl.StandardClient.<init>(StandardClient.java:99) ~[mariadb-java-client-3.1.4.jar:?] at org.mariadb.jdbc.Driver.connect(Driver.java:70) ~[mariadb-java-client-3.1.4.jar:?] at org.mariadb.jdbc.Driver.connect(Driver.java:101) ~[mariadb-java-client-3.1.4.jar:?] at org.mariadb.jdbc.Driver.connect(Driver.java:27) ~[mariadb-java-client-3.1.4.jar:?] at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:52) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:374) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:106) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:649) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:531) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:731) ~[commons-dbcp2-2.9.0.jar:2.9.0] at com.fortify.ssc.init.process.MigrationRunner.runMigration(MigrationRunner.java:54) ~[ssc-init-24.2.0.0186.jar:?] ... 40 more Caused by: java.net.SocketTimeoutException: Connect timed out at sun.nio.ch.NioSocketImpl.timedFinishConnect(NioSocketImpl.java:551) ~[?:?] at sun.nio.ch.NioSocketImpl.connect(NioSocketImpl.java:602) ~[?:?] at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:327) ~[?:?] at java.net.Socket.connect(Socket.java:633) ~[?:?] at org.mariadb.jdbc.client.impl.ConnectionHelper.connectSocket(ConnectionHelper.java:131) ~[mariadb-java-client-3.1.4.jar:?] at org.mariadb.jdbc.client.impl.StandardClient.<init>(StandardClient.java:99) ~[mariadb-java-client-3.1.4.jar:?] at org.mariadb.jdbc.Driver.connect(Driver.java:70) ~[mariadb-java-client-3.1.4.jar:?] at org.mariadb.jdbc.Driver.connect(Driver.java:101) ~[mariadb-java-client-3.1.4.jar:?] at org.mariadb.jdbc.Driver.connect(Driver.java:27) ~[mariadb-java-client-3.1.4.jar:?] at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:52) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:374) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:106) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:649) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:531) ~[commons-dbcp2-2.9.0.jar:2.9.0] at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:731) ~[commons-dbcp2-2.9.0.jar:2.9.0] at com.fortify.ssc.init.process.MigrationRunner.runMigration(MigrationRunner.java:54) ~[ssc-init-24.2.0.0186.jar:?] ... 40 more 2024-07-30 11:27:18,907 [ERROR] org.springframework.boot.SpringApplication - Application run failed com.fortify.ssc.config.AutoConfigException: Application is not configured at com.fortify.ssc.webapp.SscApplicationConfigurer.autoconfigure(SscApplicationConfigurer.java:151) ~[classes/:?] at com.fortify.ssc.webapp.SscApplicationConfigurer.lambda$buildContextInitializer$1(SscApplicationConfigurer.java:127) ~[classes/:?] at org.springframework.boot.SpringApplication.applyInitializers(SpringApplication.java:605) [spring-boot-2.7.18.jar:2.7.18] at org.springframework.boot.SpringApplication.prepareContext(SpringApplication.java:374) [spring-boot-2.7.18.jar:2.7.18] at org.springframework.boot.SpringApplication.run(SpringApplication.java:307) [spring-boot-2.7.18.jar:2.7.18] at org.springframework.boot.web.servlet.support.SpringBootServletInitializer.run(SpringBootServletInitializer.java:175) [spring-boot-2.7.18.jar:2.7.18] at org.springframework.boot.web.servlet.support.SpringBootServletInitializer.createRootApplicationContext(SpringBootServletInitializer.java:155) [spring-boot-2.7.18.jar:2.7.18] at org.springframework.boot.web.servlet.support.SpringBootServletInitializer.onStartup(SpringBootServletInitializer.java:97) [spring-boot-2.7.18.jar:2.7.18] at com.fortify.ssc.webapp.SscSpringBootApplication.onStartup(SscSpringBootApplication.java:62) [classes/:?] at org.springframework.web.SpringServletContainerInitializer.onStartup(SpringServletContainerInitializer.java:174) [spring-web-5.3.31.jar:5.3.31] at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4901) [catalina.jar:9.0.88] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) [catalina.jar:9.0.88] at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1345) [catalina.jar:9.0.88] at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1335) [catalina.jar:9.0.88] at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?] at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) [tomcat-util.jar:9.0.88] at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) [?:?] at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:876) [catalina.jar:9.0.88] at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:794) [catalina.jar:9.0.88] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) [catalina.jar:9.0.88] at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1345) [catalina.jar:9.0.88] at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1335) [catalina.jar:9.0.88] at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?] at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) [tomcat-util.jar:9.0.88] at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) [?:?] at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:876) [catalina.jar:9.0.88] at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:248) [catalina.jar:9.0.88] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) [catalina.jar:9.0.88] at org.apache.catalina.core.StandardService.startInternal(StandardService.java:470) [catalina.jar:9.0.88] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) [catalina.jar:9.0.88] at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:951) [catalina.jar:9.0.88] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) [catalina.jar:9.0.88] at org.apache.catalina.startup.Catalina.start(Catalina.java:735) [catalina.jar:9.0.88] at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?] at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?] at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?] at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?] at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345) [bootstrap.jar:9.0.88] at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:473) [bootstrap.jar:9.0.88] 30-Jul-2024 11:27:18.910 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal Error during ServletContainerInitializer processing javax.servlet.UnavailableException: Failed to start SSC application: Application is not configured at com.fortify.ssc.webapp.SscSpringBootApplication.onStartup(SscSpringBootApplication.java:65) at org.springframework.web.SpringServletContainerInitializer.onStartup(SpringServletContainerInitializer.java:174) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4901) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1345) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1335) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:876) at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:794) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1345) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1335) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:876) at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:248) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) at org.apache.catalina.core.StandardService.startInternal(StandardService.java:470) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:951) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) at org.apache.catalina.startup.Catalina.start(Catalina.java:735) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:568) at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:473) 30-Jul-2024 11:27:18.921 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal Context [] startup failed due to previous errors 30-Jul-2024 11:27:19.535 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [org.mariadb.jdbc.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered. 30-Jul-2024 11:27:19.535 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [oracle.jdbc.OracleDriver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered. 30-Jul-2024 11:27:19.536 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [com.microsoft.sqlserver.jdbc.SQLServerDriver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered. 30-Jul-2024 11:27:19.537 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [ROOT] appears to have started a thread named [Log4j2-TF-14-Scheduled-2] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread: java.base@17.0.11/jdk.internal.misc.Unsafe.park(Native Method) java.base@17.0.11/java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:252) java.base@17.0.11/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:1674) java.base@17.0.11/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1182) java.base@17.0.11/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:899) java.base@17.0.11/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1062) java.base@17.0.11/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1122) java.base@17.0.11/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) java.base@17.0.11/java.lang.Thread.run(Thread.java:840) 30-Jul-2024 11:27:19.539 SEVERE [main] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [org.springframework.boot.SpringBootExceptionHandler.LoggedExceptionHandlerThreadLocal] (value [org.springframework.boot.SpringBootExceptionHandler$LoggedExceptionHandlerThreadLocal@a66924b]) and a value of type [org.springframework.boot.SpringBootExceptionHandler] (value [org.springframework.boot.SpringBootExceptionHandler@51c4ee48]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak. 30-Jul-2024 11:27:19.632 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio2-8080"] 30-Jul-2024 11:27:19.634 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["https-jsse-nio2-8443"] 30-Jul-2024 11:27:19.635 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in [59894] milliseconds
There are some interesting lines:
2024-07-30 11:27:18,907 [ERROR] org.springframework.boot.SpringApplication - Application run failed com.fortify.ssc.config.AutoConfigException: Application is not configured ... 30-Jul-2024 11:27:18.910 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal Error during ServletContainerInitializer processing javax.servlet.UnavailableException: Failed to start SSC application: Application is not configured ... 30-Jul-2024 11:27:18.921 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal Context [] startup failed due to previous errors 30-Jul-2024 11:27:19.535 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [org.mariadb.jdbc.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered. 30-Jul-2024 11:27:19.535 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [oracle.jdbc.OracleDriver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered. 30-Jul-2024 11:27:19.536 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesJdbc The web application [ROOT] registered the JDBC driver [com.microsoft.sqlserver.jdbc.SQLServerDriver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered. 30-Jul-2024 11:27:19.537 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [ROOT] appears to have started a thread named [Log4j2-TF-14-Scheduled-2] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
I would really appreciate some help.
Best regards
