General Availability of Micro Focus ArcSight Logger 6.71, ArcMC 2.91 & Smart Connector 7.12.0
We are very excited to announce the general availability of Micro Focus ArcSight Logger 6.71, ArcMC 2.91 and Smart Connector 7.12.0
Here are the new features and improvements.
Arcsight Logger 6.71:
Ability to add EB Receiver with IP/Hostname format.
Various security fixes and bug fixes.
ArcSight Management Center 2.91:
Setting Generator ID during Scan Host.
ArcSight SmartConnector Framework 7.12.0:
Improved Smart Connectors for
- Microsoft Azure Monitor Event Hub
- AWS Cloudwatch
- VMware Web Services
- Cisco Secure ACS Syslog
- IP Flow (Netflow/J-Flow)
- McAfee ePolicy Orchestrator DB
- Symantec Endpoint Protection DB
Improved parsing and mapping for
- Cisco ASA Syslog
- Cisco Secure ACS Syslog-Juniper JUNOS Syslog
- Proofpoint Enterprise Protection and Enterprise Privacy Syslog
- VMware ESXi Server Syslog
Various security fixes, feature updates, and bug fixes.
Please note that all Logger, ArcMC and Smart Connector customers with active support subscription can upgrade to Logger 6.71, ArcMC 2.91 and Smart Connector 7.12.0.If you own these components individually, then you can access the new software from the software entitlement portal.
ADP / Security Data Platform customers - Please contact technical support to obtain the software for Logger 6.71 and ArcMC 2.91. Smart Connectors 7.12.0 can be found on the software entitlement portal.
Documentation can be found as follows:
Logger 6.71, ArcMC 2.91 and Smart Connector 7.12.0 Support Matrix
Logger 6.71
Logger 6.71 Release Notes
Logger 6.71 Administrator’s Guide
Logger 6.71 Installation Guide
Logger 6.71 Web Services API Guide
Logger 6.71 Best Practices Guide
ArcMC 2.91
ArcMC 2.91 Release Notes
ArcMC 2.91 Administrator's Guide
Smart Connector Framework 7.12.0
Smart Connector Framework 7.12.0 Release Notes
Smart Connector Framework 7.12.0 User Guide
Smart Connector Framework 7.12.0 Configuration Guides
If you have any questions, please contact Customer Support.
Thank you,
ArcSight Product Team
    Thanks  for the update.  Unfortunately this is not working here, still seeing the "Error (null)" message with 7.11 or 7.12.  This is on ArcMC 2.90 or 2.91.
    7.10 working fine but defaulting to 32 bit restore.
    If I had any hair left, I would tear it out.
