DB reconnect issues to SQL2012 using VisualCOBOL8.
Hi Gents,
Any experiences using msodbc and unixODBC on RHEL  with VisualCOBOL8 on RHEL to connect SQL2012?
We are currently experiencing DB reconnect issues to our SQL2012 with our COBOL 8 programs on RHEL8 , using using msodbcsql18 and unixODBC2.3.11 .
It was working before with the same COBOL source codes on RHEL6, COBOL5express, using msodbcsql11 and unixODBC2.3.0.
Thanks
Parents
    Hi Aldous Carlos,
    Thanks for sharing some details about your new environment. It sounds like you were using Server Express 5.1 previously, and are now moving to Visual COBOL 8.
    Can you let us know the exact error message you receive when you try to connect?
    Also, have you tried using the isql utility (interactive SQL prompt, which I believe is provided with UnixODBC) to confirm the UnixODBC configuration is set up correctly on the new machine?
  • 0   in reply to
    Hi Again,
    I've just noticed that you are connecting to Microsoft SQL Server 2012. Please note that this version of SQL Server is not supported in Visual COBOL 8.0 . Please see this page in the Visual COBOL documentation for information, by Visual COBOL product version, on supported Relational Database Management Systems and versions.
    We tried to connect to a SQLServer2019  to see if the db reconnect improves, but still had the same result.
    Thanks.
Reply Children
No Data
