Alternative for CBL_GET_PROGRAM_INFO in JVM Cobol
In our application we use the CBL_GET_PROGRAM_INFO function embedded in a copy to determine and output the name of the active program for logging purposes.
Now we want to migrate our application to JVM Cobol.
Our search for an adequate function there has so far been unsuccessful.
How can the program name be determined there?
    Are you using Functions 8 or 10 of this library routine?
    https://www.microfocus.com/documentation/visual-cobol/vc90/EclUNIX/HRCLRHCALL2J.html
    Here is the code snippet that we use in our legacy application. Returns no result in JVM-Cobol. The function returns with status 181.
    77 Prog-Info-Funktion pic x(4) comp-5.
    01 Prog-Info-Param-block.
    03 Prog-Info-size pic x(4) comp-5 value 20.
    03 Prog-Info-flags pic x(4) comp-5 value 1.
    03 Prog-Info-hWind pointer.
    03 Prog-Info-prog-handle pointer.
    03 Prog-Info-attributes pic x(4) comp-5.
    77 Prog-Info-name-buf pic x(100).
    77 Prog-Info-name-len pic x(4) comp-5 value 100.
    77 Prog-Info-status-code PIC X(2) COMP-5.
    CALL-GET-PROGRAM-INFO SECTION.
    move 0 to Prog-Info-Funktion
    call "CBL_GET_PROGRAM_INFO" using by value Prog-Info-funktion
    by reference Prog-Info-param-block
    by reference Prog-Info-Name-buf
    by reference Prog-Info-Name-len
    returning Prog-Info-Status-Code
    move 7 to Prog-Info-Funktion
    returning Prog-Info-Status-Code.
  • Suggested Answer
    0   in reply to
    The problem is because the size of the parameter block is not 20 bytes when compiling to JVM, as the pointers are 8 bytes. If you add this before making the call
    move length of Prog-Info-Param-block to Prog-Info-size
    it will work correctly regardless of the pointer size.
    Thanks for the tip. This is how it works now.
    Some things can be so simple.
