DBCS for Rumba+
how to set configuration for Rumba+ to display MAP with DBCS
Labels:
Rumba
Parents
  • Verified Answer
    +1
    Hi Su Jerry,
    Could you please explain a bit more on what you mean by MAP with DBCS?
    Rumba+ Desktop version 9.5 was the last release that included a package which supports Japanese DBCS, however it is no longer officially supported.
  • Verified Answer
    +1 in reply to
    My environment is as follows:
    windows 10 and Enterprise Developer 8.0
    Use the Rumba+ Desktop v10.1(provide by ED 8.0) to connect to server and  run the CICS to display  BMS map.
    I want to display the Chinese character on the screen, so how to configure the Rumba+ can do that?
  • Verified Answer
    +1   in reply to
    We do not support a DBCS version of Rumba+ Desktop.
    With that said, you can try setting the Windows locale to Simplified Chinese and in the Rumba+ Desktop Mainframe Display configuration, under Connection\TN3270, choose Host Characer Set / Code Page: English (United States Alternate 3) 37.
    If you're still not able to see the characters, please open a case with Technical Support. Information on how to open a case is located here:
    portal.microfocus.com/.../KM000004141
  • Verified Answer
    +1 in reply to
    what brand of TN3270 do you recommend to connect the ED server to display Traditional Chinese?
Reply Children
