While connecting with Rumba 10 using VB6 automation error facing
We have written code for connecting rumba app with our app. Earlier it has working fine with Rumba 8.1 Version. After upgradation version of Rumba 8.1 to 10.1 its gives automation error. Same code not working with Rumba 10.1 Version. Any help will be much appreciated.
Labels:
Rumba
Parents
    Hello Manesh,
    can you please elaborate a bit on your problem.
    - How do you connect with RUMBA in your VB Application. What API is used?
    - Do you get an Error Message? Explain what you mean by automation error.?
    - Did you just upgrade the RUMBA version or are more changes involved?
    - Can you please provide a code snippet to see what is failing.
    If you can't share the information in this forum, please open a case with our support team (https://portal.microfocus.com). The team will work with you to resolve your issue.
    cheers
    andree
    Hi Andree We have Written VB6 code for that
    please find the below block for that , in that it will stuck on doevent it will throws automation error.5706.Code of Rumba Connect Screenshot.docx
    ObjMFDisplay.Connect
    DoEvents
    If ObjMFDisplay.Connect = False Then ' Connects the Display control
    waitAWhile (20)
    ObjMFDisplay.Disconnect
    waitAWhile (20)
    DoEvents
    waitAWhile (20)
    End If
    End If
    If Check_Screen(22, 57, 4, "===>") = False Then
    waitAWhile (20)
    waitAWhile (20)
    DoEvents
    DoEvents
    DoEvents
    DoEvents
    DoEvents
    DoEvents
    DoEvents
    DoEvents
    MsgBox "Unable to get to Signon Screen", vbCritical + vbOKOnly
    Exit Sub
    End If
    End If
    End If
    End If
  • Verified Answer
    +1 in reply to
    - Did you just upgrade the RUMBA version or are more changes involved?--- Yes we have upgraded Rumba 8.1 to 10.1
    -Can you please provide a code snippet to see what is failing. --- Doevent
  • Suggested Answer
    0   in reply to
    Hello Manesh,
    this type of request are difficult to handle in the forum but the support teams can work with you.
    Could you please open a ticket with the support team to assist you in the best possible way.
    I can replicate a Run-time error '-1 (ffffffff), but it only occur in the VB 6 IDE. After I compile the project I have no issues.
    I'm sure you're aware but Visual Basic 6.0 IDE or Visual Studio 6.0 IDE as a whole moved out of extended support on April 8, 2008 by Microsoft.
    If you're going to open a case please make sure the problem occurs in the runtime.
    it would help us f you provide a simple VB6 project code to reproduce your error.
    cheers
Reply
  • Suggested Answer
    0   in reply to
    Hello Manesh,
    cheers
Children
No Data
